Solar is hard to justify when you add financing costs ... And US$80K is crazy pricing .. it may well be normal/local pricing, but still silly (target market being those with more $ than sense)... but anyways
if you peruse this forums, you'll see frequent comments from those much more knowledgeable on this subject than I, that the cheapest PV production is the one not needed (ie, reducing kWh consumption is often cheaper than adding extra PV production). and to do that with a positive ROI means more data (usually)... Hence, as others have noted/alluded to:
- installing some electric monitoring will go a long ways to providing better info regarding future upgrades (the Emporia Vue being one such option)
and to check into any possible alternate TOU rate plans bet matched to your usage patterns? using just mentioned monitoring data, if need be
- Not sure the specifics with PG&E, but other CA NEM 2.0 allowed (without being pushed to NEM 3.0)
Systems that are 10 kilowatts (kW) or smaller can be increased by no more than 1 kW.
Systems that are larger than 10 kW can be increased by no more than 10% of the existing system size.
... the challenge (pre NEM 3.0) was that solar installers only wanted profit from larger jobs, and finding anyone willing to install extra panels *while maintaining original system warranty* became a a real challenge (near impossible) for large, well-known name brand grid-tied systems (panels, inverters, etc)
Which the recent collapse of residential PV market, and some persistence, you _might_ be able to get someone to add to your existing system at a reasonable rate (assuming easy room on roof for extra couple of panels, the panels compatible with current system, and the extra PV production not pushing previously designed system (inverter) into requiring an upgrade. if a whole roof warranty is in place (ex, I had a full roof lift and lay a few years prior), I'd check with roofer to see about adding additional panel mounts, while maintaining roof warranty. Then have company authorized for your system (Tesla) add the couple of extra panels to existing system
- I'm assuming extra PV production desirable for the AC (regardless if power optimized vs your current unit)
Out of curiosity... having dealt with the much older crowd that often like keeping the house nice and toasty warm, leading to others wanting a cooler room to retreat into. Is this your scenario? I ask in case that portable AC unit usage is relatively short term (couple of years.. parents move out) vs long-term plan?
As for EV charging... I take it you work someplace where your normal work site doesn't have free/cheap/subsidized charging onsite? (I was lucky that my last couple of employers all had onsite chargers for employees)
Not to count on... but worth checking into... other sites near your office... especially if there is a business (owner) that is friendly to your company that might allow you to use their onsite EVSE charger? again.. free or at a desirable rate, at least.
Or see if enough interest amongst others at your location to get site to add EVSE chargers(s)? obviously depends on specific situation if this might be practical or not.
