noy897
My wife and I recently moved back to her parents' house in Northern California. Before we moved here, her parents used to receive a yearly credit from PGE, usually around $700 to $800, because their solar panels produced more energy than they needed under NEM 2.0. However, things have changed since we've started living here. We have a Tesla Model Y and run a portable AC unit for more than 10 hours a day. As a result, the estimated annual true-up cost has shot up to a range of $2,500 to $3,000, which is roughly $200 to $250 per month. Since we plan to stay here and take over the household, we're considering investing in more solar panels.
Here's what I'm thinking:
- I know that if I add more solar panels, I'll be moved to NEM 3.0, which doesn't offer as much in terms of annual credits. To avoid the hassle of permits and buying additional solar panels, I'm thinking about getting two EcoFlow 21kWh systems with over 2kW of solar panels each. Essentially, I'd have a 42kWh system with solar panels. One system would be solely for charging the car, and the other would power our room, including the portable AC. This investment would cost around $30,000, but it's eligible for a 30% tax rebate. Most importantly, since I don't need a permit for this setup and don't have to modify the existing panels or notify PGE, I can avoid being switched to NEM 3.0. If I totally offset my consumption then we can possibly start getting those credits back. You can check out the product here: EcoFlow Delta Pro 21.6kWh and 2,680 Watts of Solar Panels Total Solar Generator Kit.
- Another option is teaming up with Vivit. They've proposed installing a 30kW battery system and more solar panels for around $50,000 or more. However, this would switch me to NEM 3.0.
