noy897
Thank you everyone for all your input! I want to give as many details as possible.Why spend $12,000 for a battery (less than 100% efficient) to store power during peak times of the day, and use to charge your car at night when you could have bought power at off-peak rates with credits earned on-peak?
Net metering is 100% efficient (less any fixed fees; is that $11/month? Compare to $12k battery, call that $100/month amortized over a decade.) Actually > 100%, if you backfeed any power during on-peak, and draw off-peak.
That is why I suggested added PV on a zero-export hybrid (batteries optional) inverter. If you don't make enough kWh today, you could make more to fix it.
Do you have room for more rooftop PV? What kind of shingles/roofing?
Do you have room for ground mounts?
"and run a portable AC unit for more than 10 hours a day. As a result, the estimated annual true-up cost has shot up to a range of $2,500 to $3,000, which is roughly $200 to $250 per month."
Do you think the portable A/C is most of that consumption?
Does this portable A/C have 2 hoses, or not?
You need to determine what it's consumption is. And efficient window unit or mini-split might be an improvement.
You must be somewhere hot. Where is the solar gain coming from? An uninsulated roof? Windows?
1) I have included our prior bills with and without trueup
2) I have also included data from the solar company
3) I have included data from the tesla on how much kwh it charged from my home
4) I have included information about the AC
OLD BILL
End Date | Net Peak Usage (kWh) | Net Off Peak Usage (kWh) | Net Use (kWh) | Estimated NEM Charges Before Taxes | Estimated NEM Charges After Taxes |
02/11/2021 | 53 | -123 | -70 | -85.01 | -58.03 |
03/15/2021 | 115 | -661 | -546 | -108.65 | -108.82 |
04/12/2021 | -113 | -863 | -976 | -240.37 | -240.66 |
05/13/2021 | -175 | -1361 | -1536 | -330.60 | -331.99 |
06/14/2021 | 152 | -1146 | -994 | -304.99 | -306.45 |
07/14/2021 | -1 | -860 | -861 | -204.91 | -204.44 |
08/15/2021 | 176 | -713 | -537 | -116.58 | -116.74 |
09/14/2021 | 21 | -646 | -625 | -144.12 | -84.25 |
10/13/2021 | 55 | -775 | -720 | -183.49 | -183.70 |
11/12/2021 | 39 | -518 | -479 | -101.58 | -101.72 |
12/13/2021 | 224 | -119 | 105 | 41.80 | 41.83 |
TOTAL | 528 | -7791 | -7264 | -$1,772.80 | -$1,774.97 |
NEW BILL
Bill Period End Date | Net Peak Usage (kWh) | Net Part Peak Usage (kWh) | Net Off Peak Usage (kWh) | Net Use (kWh) | Estimated NEM Charges Before Taxes | Estimated Total NEM Charges |
02/12/2023 | 417 | 0 | 678 | 1095 | $406.16 | $406.49 |
03/14/2023 | 263 | 111 | 488 | 862 | $301.98 | $302.24 |
04/13/2023 | 95 | 84 | 239 | 418 | $171.98 | $172.11 |
05/14/2023 | 21 | 86 | 68 | 174 | $104.60 | $104.65 |
06/12/2023 | -37 | 79 | -44 | -2 | $55.88 | $55.88 |
07/13/2023 | 96 | 183 | 103 | 382 | $211.66 | $211.78 |
08/13/2023 | 478 | 264 | 278 | 1020 | $509.46 | $509.77 |
09/12/2023 | 349 | 221 | 353 | 923 | 450.91 | 451.23 |
10/12/2023 | 279 | 176 | 260 | 714 | $282.85 | $282.99 |
TOTAL | 1944 | 1144 | 2364 | 5496 | $2,495.48 | $2,497.14 |
SOLAR DATA
2021 Production 18.1 mWh
2022 Production 18.7 mWh
2023 Production 15.5 mWh
I have also attached a pic of our current solar setup.
TESLA DATA:
We purchased the Tesla in September of last year and since then the Tesla has consumed 6,967.88 kWh of charging.
From 2/12/23-10/12/23 - 6,725.25 kWh
AC INFO:
I have a watt meter and it showed between 900-1200watts. This is the AC model:
