So I'm barely in the finishing stage of my 9.45kW AC / 8.7kW DC Enphase IQ8+ setup, and I already want to start expanding...
I've got 20 panels up on the roof, should have the remaining 10 up soon.
This is what the setup looks like currently:
![1709594244519.png 1709594244519.png](https://diysolarforum.com/data/attachments/200/200071-491e24a66a6da0c0d8fce764dd77e6e6.jpg)
Here's the wrinkle: NEM 2.0 closed back in April last year (this plan was submitted before then, and got in). Any additions would kick me to NEM 3.0, which sucks (except adding batteries -- that's ok).
Question #1: My understanding is adding <10% / 1kW is doable while staying on NEM 2.0. Anyone actually done this? Did it require an entire new plan set / AHJ / PGE inspection?
Adding batteries is the obvious other idea (and can be done under NEM 2.0), although I've got plenty of additional roof to add panels on... Assuming I want to add panels, off-grid sounds like the only practical / PGE-legit way of doing it.
If I do add off-grid, that sounds like I then need to have dedicated batteries. It also sounds like I'd have to figure out some way of either semi-permanently segregating some loads to that off-grid panel (EV / hot water maybe?), or figure out some sort of ATS system.
On to my crazy plan:
![1709593516427.png 1709593516427.png](https://diysolarforum.com/data/attachments/200/200070-a98aedef16292aed36eb3e3e65f7429b.jpg)
What the heck is going on here?
All the stuff in red is "new".
Basically:
I'd add as many new solar panels as I feel like, plus an off-grid AIO, plus a bunch of cheap LFP cells / EG4 server batteries, etc. This off-grid system would charge up the huge cheap non-UL batteries until they're fully charged. At this point, the ATS would be triggered, and they'd start dumping into the new "off grid" sub panel + Encharge 5P battery until it's charged.
At that point, the ATS goes back into the normal position (IQ battery 5P --> Rest of house), and that discharges, while the Huge DIY battery starts charging from the off grid solar again.
This is janky, I know.![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Limitations I can see:
1. Lots of cycles of the IQ Battery
2. Lots of wastage going from Offgrid PV -> 48 V battery -> 120 V -> IQ Battery DC, then when switched over, IQ Battery DC -> AC -> House loads.
3. Cost. Off grid PV (6kW / $2000?) + AIO (6kW / $1300?) + Cheap DIY battery (cheap 15x EVE LF304 , <$2000 15kWish) + IQ Battery ($3300)+ Extra IQ Gateway ($700). Total $10k or so.
Question #2: Do off-grid battery installs in california require them to be UL 9540?
I'm open to other suggestions that are less janky that don't lose my NEM 2.0 status...
Basically:
