Electric Personality
- May 9, 2020
- 148
Luckily, the cabin (upstate NY) is oriented north/south, but is in deeply wooded trees. It will be mostly three season. Just trying to sketch out a system for my friends that own it. The summer season will light up the western side of the roof for maybe 4 hours maybe a little more, but their load is fairly light. A 1 hp on demand water pump, a fairly efficient 7 cu. ft vissani fridge, led lighting, and the kicker, plumbed for a washer and (propane) dryer.
I know very little about mounting panels to a steel roof, I have some reading to do. My thoughts are, it would be great if I could angle the panels on the western face of the roof to the south, but, that would present a lot “fetch” for snow to build up. If the panels were mounted flat, I imagine that it would not be much of an issue, but less harvest. Guessing 4000 watts would fit up there easy. Maybe more, don’t have the actual dimensions yet.
Back of the napkin math, how big would you go in batteries and inverter?
Cabin is wired with a 240 panel, but no 240v appliances. Wood stove. They currently use a generator for everything.
Thinking a 48 volt system, probably an EG4 all in one, as big a battery as they can afford (min 100 ah? I would be happier with twice that, but they do have a generator) but still in learning mode.
Open to any and all ideas. Previous experience was getting my trailer off the generator habbit. Diy’d a battery for that, been working great for a few years, can even run the ac for a while.
