Thanks .... I guess i had never paid any attention to the MINIMUM voltage specs for an MPPT controller.Its a dc-dc charger for a reason. It takes lower voltages and ramps it up. And a charge controller takes higher voltages and lowers them.
Your alternator only outputs 14.4v before you run 10ft of wiring. Theres not enough voltage to charge. You can power an inverter and a dc power supply at 16v+ into a controller.
1b) The PV voltage must exceed Vbat + 5V for the controller to start. Thereafter the minimum PV voltage is Vbat + 1V
Are there anymore made in the US, or is it designed by a US company but made in China?If you go DC-2-DC, which i recommend you want to make sure you get a good solid US one -- We love for ppl to use those cheap Chinese DC-2-DC converters at work and then put a good constant load on them ... this allows for our boredom to be interrupted by the local VFD trying to get to the burning vehicle on time before the well-head or something catches fire -- they never make it of course -- but it kills a couple of hours of the day with free entertainment ... also typically when we hear the fire alarm at work someone puts a bag of popcorn in the microwave on the way out just in case its a truck fire ... and if so we go back - get the popcorn and our chairs - sit outside and try to figure out what part from China caused the fire ...![]()
My DC-DC/MPPT is from a Canadian company, but I don't know it was designed or made.
HiI am looking to have better control of the charge current and voltage by having 1 unit manage Alternator, AC, and solar instead of having 3 independent charge sources landed on the battery. I want to be able to cut off the charge voltage and load independently and the Easy Solar and a Samlex inverter charger i am looking at have remote control capabilities.
I didn't realize the USAre there anymore made in the US, or is it designed by a US company but made in China?
I didn't realize that the US was the only place in the world that designed or made good solid quality equipment. I guess I'll have to throw out all my rubbish Victron and RedArc gear as those European and Aussie engineers must be incompetent. I'll give Donald Trump a call and see what he recommendsIf you go DC-2-DC, which i recommend you want to make sure you get a good solid US one -- We love for ppl to use those cheap Chinese DC-2-DC converters at work and then put a good constant load on them ... this allows for our boredom to be interrupted by the local VFD trying to get to the burning vehicle on time before the well-head or something catches fire -- they never make it of course -- but it kills a couple of hours of the day with free entertainment ... also typically when we hear the fire alarm at work someone puts a bag of popcorn in the microwave on the way out just in case its a truck fire ... and if so we go back - get the popcorn and our chairs - sit outside and try to figure out what part from China caused the fire ...![]()
I didn't realize that the US was the only place in the world that designed or made good solid quality equipment. ..
Hi
Have you looked at the RedArc BMS system - has AC / DC to DC and Solar input all in one. Used extensively here in Australia. Have a presence globally. Only drawback is the low VoC max of the solar input. It has a "Green Option" which lets it use both Alternator and MPPT or can switch between the two depending on which is the most effective
Link here https://www.redarc.com.au/the-manager30
If you are looking for a static solution look at the MPPSolar range of products https://www.mppsolar.com/v3/
Regards
The Lithium Battery Isolation
Manager (Li-BIM) isolates the two battery
systems, chassis, and coach, in a motorhome. This
prevents loads in one system from discharging both. It
also connects the two battery systems together during
charging. Both batteries are charged if either is being
charged. The coach battery is charged while driving and
the chassis battery is charged while plugged into Shore
Power at a campground.
