This might be a stupid question but I hope someone could explain this to me. I'm planning to build a system with 400W panels, the Victron 100/50 MPPT controller, a 4s2p LiFePo4 battery bank and a 1500W 12VDC to 230VAC inverter for my cabin.
The loads of the 12V system will usually be around 100-200W max (a 55w fridge and a few led lights plus charging phones etc) but I I want the option to use AC for certain short periods, like using kitchen appliances. For the 12V loads I plan to wire them from the Victron 100/50 since the 50A output limit is more than enough for those, but my question is regarding the 1500W inverter.
My understanding is that the way to do this is to wire the inverter from the battery, and when I turn the inverter on, the Victron will provide as much current as it can and the battery will provide the rest, is this the case? My 560Ah battery will be able to output 280A continuously, although capped at 200A for the BMS, but I guess that my worry is to hurt the Victron 100/50 by drawing more than 50A.
Grateful for all tips and thoughts.
