Could be an idea.... already though of that...What kind of battery is this? If you have multiple, it might be worth tearing them down and re-assembling a larger 48V bank from the cells.
I'm in Havana, Cuba... would have to import almost everything...!!!!
No, sorry, don't have any... but almost certain they are 18650 or 27000 modules... with an included BMS...If you have any of those handy, open it up and have a look at how it's wired. Take photos if you can.
Yes, I know... but here is VERY DIFFICULT to import ... ANYTHING!!!What? You think most of us aren't importing our LiFePO4 cells? LOL! I would guess than 90% of the DIY battery installs here are imported from China.
I am in a very similar situation to Songomx. I am not in Cuba but I understand his situation with importation there. I have a large 72v battery system that I use for something similar to an electric motorcycle (not the same, but same battery configuration of 72V 40Ah). The only inverter I have found that is capable of accepting 72v is around $1,100. That is just too much to pay. I purchased a pretty decent 72v to 12v DC to DC converter but the max on that unit is only 600 watts. This does not give me the ability to run a nice 2,000 watt inverter to get AC. So now I am on the hunt again for something that works. That is if I am correct that the 600 watt max on the converter limits the output from the inverter? Please tell me if I am wrong. And to Songomx, sorry to hijack your thread. If you run all DC you should be able to use that battery but if you need big wattage on AC then you will have to look at other options.
Ok!Keep studying...!!!
Well, I'm not an expert but I can check with each technology provider ... anyway, specialized gloves, plastic goggles and all that stuff is mandatory for working HV electricity... and even for 48 V DC battery arrays... you can get harmed if short-circuiting a cell on those batteries...Ok!
If you are ok with me asking, what sort of protective equipment do you consider important when working on HV battery? (>48V)
The only reason I ask is, the risk of DC arc shock intimidates me and from what I’ve read, rubber gloves with no small holes or cracks combined with leather glove for physical protection is common?
Anyways, I hope you can find a good solution in time with research.
Good luck
