I have 2 Growatt 5000 ES installed in Parallel with 2 x Blue Carbon 48V 200Ah Lithium Battery Pack For Solar Home System. PVs are Mono 10 x 550W. 5 panels each in series to each Inverter. Priority is set to Solar, Utility and Battery.
My inverters have been shutting down (No error codes) due to what appears to be "over charging" from the Solar panels. i.e. Not enough consumption of the power being generated. Question .. is this really possible that no to minimal load will cause a problem? If so or if not I would appreciate any inputs. I have been having to shut off the Solar panels and then restart the Inverters and then turn the Solar input back on.
