Hedges
I See Electromagnetic Fields!
- Mar 28, 2020
- 23,157
It's not the problem of building a 96V pack (though finding a BMS that is tried and tested may be) it's then charging that from the 48V (or the 230V AC) that will be coming from the panels / inverters / 48V LiFePO4 bank.
REC BMS comes in 16s blocks and can be connected up to 128s.
It uses contactors.
How about two contactors, one on battery+, other on battery-
Connects two 48V battery chargers, one from middle to battery+, other from middle to battery-.
(This assumes BMS tolerates cell divergence, as the two 48V sections may not be same voltage. Should be adjustable parameter.)
Use four contactors total. One for each charging source, and one for each end of load. Well, maybe only one needed for load, so three contactors.
Need to isolate load from charging source to prevent excessive reverse-polarity voltage seen by charger.
This would be an all-lithium system, no AGM.
