Let's talk about MPPT...
You have a panel that is spec'd out as below..
You put it in a 6s2p configuration..
Your "solar generator" has a limits of 1600w, 11-150v, 15a..
Will a MPPT controller adjust the voltage above the MPP rating on the panels?
Meaning to get 1600w at 15a you would need the voltage to be 106.67..
That string MPP would be 100.62v...
Hopefully that makes sense...
Thanks!
- Max Power Output(W): 210W
- Voltage MPP Vmp(V): 16.77V
- Current MPP Imp(A): 12.48A
- Voltage Open Circuit Voc(V): 19.83V
- Short Circuit Current Isc(A): 13.09A
Thanks!
