Genasun GV-10-Li-14.2V, 10.5 A MPPT Charge Controller & 150watt panel compatible?
Smeeg
Can someone double check if these two are compatible I’m under the maximum VOC but the charge controller says 140watt maximum & the panel is 150watts thank you.
(Battery will be bioenno 12ah part # PVC, BLF-1212AB)
Genasun charge controller
Specifications: ^
  • Max. Recommended Panel Power: 140 W
  • Rated Battery (Output) Current: 10.5 A
  • Charge Voltage CC/CV 14.2V (3.55 V per cell)
  • Max Panel Voltage: 34 V
  • Max. Recommended Panel Voc at STC: 27 V
  • Min. Battery Voltage for Operation: 8.5 V
  • Operating Temp. Range: -40 °C - 85 °C
  • Night Consumption: 0.9 mA
  • Environmental Protection: IP40, Conformal Coating, Nickel-Plated Brass & Stainless Hardware
  • Connection: 4-position terminal block for 10-30 AWG wire
  • Weight: 6.5 oz., 185 g
  • Dimensions: 5.5" x 2.5" x 1.29"
  • Certifications: cETLus, Class 1 Div.2, CE , FCC, RoHS
Rich solar 150watt panel
Specifications ^​
  • Model: RS-M150
  • Maximum Power(Pmax): 150W
  • Maximum Power Voltage(Vmp): 19.5V
  • Maximum Power Current(Imp): 7.69A
  • Open Circuit Voltage(Voc): 23.6V
  • Short Circuit Current(Isc): 8.06A
  • Maximum System Voltage(Vmax): 1000VDC
  • Temperature Range: -40°C ~ +185°C
  • Weight: 18.0 lbs
  • Dimensions: 42.5 x 27.6 x 1.2 in
