cyberfranklin
Hi all,
Beginners Question: I am working to design a small (12 panel) ground mounted system with an EG4 6.5kw Off-grid inverter and charge controller and a 48 V LiPo4 battery. My question has to do with putting panels in a Series-Parallel configuration. My backyard where the panels will be installed is about 75 feet from where I plan to install the Inverter-Charge Controller and Battery. I am currently planning to use Trina 250W (Data Sheet attached). I want to take advantage of the lower amperage of configuring in-series (lighter gauge copper) and also minimize the wider-array degradation that is less likely to be invoked when a panel is shaded in a parallel configuration. So, I am configuring this way:
2 Trina 250W panels in series
Open Circuit Voltage (VoC)-volts= 37.6 * 2 (panels) = 75.2 volts
Maximum Power Current (amp)= 8.27
6 (series) Pairs of those panels in parallel
volts=volts in a parallel configuration 75.2=75.2 volts
8.27 amps * 6 (pairs) of panels in parallel = 49.62 amps
So, connecting with the charge controller we have:
75.2 volts
49.2 amps
Looking at the data sheet of the EG4 charge controller we understand that the max PV input is:
500 VDC
120 Max current (amp)
So, we are well below those thresholds with our series-parallel configuration.
Here is my question: the data sheet says that the charge controller range is 90VDC - 450VDC
And, as I show above, my array will only produce 75.2 volts. So, do I have to meet a 90 volts (DC) threshold to meet the requirements of the charge controller? Follow-up question, would I need to put MORE panels in series to increase the voltage?
As a newbie, am missing some fundamental concept?
Humbly willing to listen and learn. Thank you for your knowledge and time in-advance?
-G
75.2 volts
49.2 amps
500 VDC
-G
