Not entirely sure what info you are after so here are some random statements I believe to be valid
Flexible panels are popular and light but don’t last well permanently mounted. They tend to be mounted too close to have any airflow under them and the heat generated causes hotspots that kill them
Big panels are much more difficult to mount on vehicle roofs than smaller panels. The weight can be challenging to deal with
Solar arrays work much better if made of matched panels
As a rule of thumb it’s worth putting as much solar on the roof of a vehicle as will fit. It is extremely rare to here “ I wish I hadn’t installed as much solar!!”
Panels of different sizes can be used by using seperate solar charge controllers. This is very common on sailing boats because of the complicated shapes of the space available and the shading issues
You can use a solar irradiance table to estimate an arrays daily average pv energy production.
I like this one for its simplicity
www.solarelectricityhandbook.com
There are lots of ways to attach panels to vehicles but it depends on the roof material and shape as to what is best. A panel coming off the roof of a moving vehicle on to a road has been proven several times to be a killer so it’s worth doing it properly
I used 120W panels x 4 mounted between the bars of a roof rack. Feels rock solid
Hope this helps a bit
