BillCaswell New Member Joined Jan 10, 2020 Messages 78 Mar 19, 2024 #1 https://www.aliexpress.us/item/3256805292372148.html Last edited: Mar 19, 2024
FilterGuy Solar Engineering Consultant - EG4 and Consumers Joined Nov 26, 2019 Messages 7,993 Location Los Gatos CA Mar 19, 2024 #2 Yes but.... They don't appear to be UL listed so if you are getting inspected it may not pass.
W wpns Solar Joules are catch and release Joined Jul 6, 2023 Messages 1,918 Location Turks & Caicos Islands Mar 19, 2024 #3 Fyi: you can remove everything from the question mark on and get https://www.aliexpress.us/item/3256805292372148.html which is the same url without all the tracking (back to you) stuff. Not sure I’d trust aliexpress for safety-critical use.
seneysolar Solar Addict Joined Dec 17, 2023 Messages 991 Location Michigan Mar 19, 2024 #4 May i recommend Midnite for breakers and boxes. Lots of posts on here about failed/melted cheap breakers. Buy quality if you can.
BillCaswell New Member Joined Jan 10, 2020 Messages 78 Mar 19, 2024 #5 seneysolar said: May i recommend Midnite for breakers and boxes. Lots of posts on here about failed/melted cheap breakers. Buy quality if you can. View attachment 203141 Click to expand... excellent suggestion! Thanks! It's for my sailboat, so want top notch quality.
HighTechLab AKA Dexter - CTO of Current Connected, LLC Joined Sep 23, 2019 Messages 1,796 Mar 19, 2024 #6 You can't go wrong with a Midnite breaker and if you use a torque screwdriver, I'd bet that combination last a lifetime.
BillCaswell New Member Joined Jan 10, 2020 Messages 78 Mar 19, 2024 #7 wpns said: Fyi: you can remove everything from the question mark on and get https://www.aliexpress.us/item/3256805292372148.html which is the same url without all the tracking (back to you) stuff. Not sure I’d trust aliexpress for safety-critical use. Click to expand... fixed. Thanks for the tip.
再生可能 エネルギー New Member Joined Nov 28, 2019 Messages 274 Mar 20, 2024 #8 BillCaswell said: Can this breaker from AliExpress be used to disconnect a solar array? Click to expand... Hi, I would recommend looking at this DIY Forum's thread, where you can find valuale information regarding your concern. DC Circuit Breaker Fires!! One particular issue with DC circuit breakers is the polarity Polarised Solar DC Circuit Breakers - Reverse Polarity FilterGuy said: Yes but.... They don't appear to be UL listed so if you are getting inspected it may not pass. Click to expand... This is an intersting video reviewing the specifications of a circuit breaker, and in paticular (at 1:44) the Tripping Curve. How to read a Miniature Circuit Breaker (MCB) nameplate? seneysolar said: May i recommend Midnite for breakers and boxes. Lots of posts on here about failed/melted cheap breakers. Buy quality if you can. Click to expand... Yes, absolutly. There is an excelent video from bigclivedotcom showing the inside and various parts of a DC circuit breaker: Inside a 125A DC circuit breaker. Unexpected arc quenching feature.Note: A really important part to protect against are short circuits. Miniature circuit breaker might provide a good Vdc isolation,but might not be able to break the internal arc for a high Amp short circuit.Using additional fuses that can break high currents is strongly recommende.(See IEC 60947-2 if you really want to learn more about DC circuit breakers) Last edited: Mar 20, 2024
