Schneider 6848.
We had guy hit the AC lines from my inverter to the house with a mini excavator digging a trench for
french drains. It pretty much shredded the lines and there was an obvious short. The inverter shut down.
Opening the breaker panel on the solar equipment, it tripped the A/C-GridTie breaker and also the large DC breaker from the batteries.
With the damage disconnected, via breakers and clipping the damaged wires, pressing the inverters power button, it starts to come alive then
shows a fault F41 and goes no further. The Control Panel says F41 is a APS Under Voltage. I should be able
to clear the fault with the Control Panel since the cause of the fault was removed. When I clear the
fault by pressing ENTER when it says CLEAR FAULTS, it beeps, and seems like the inverter attempts to start, then
shows the F41 again. Then the SCP still shows to have a fault. I can't seem to get past this.
The manual say when you have a F41, fix the reason (sure think we did temporarily), and clear the fault.
Has anybody had a similar experience and know of a solution or a overlooked reason why it won't clear the fault?
