yazoo
I am living in the Philippines and have a house with standard Filipino 220v 60Hz. All circuits are just hot and neutral, not a ground wire to be found anywhere - which is pretty much standard here. Even supply to the main panel has no ground. I'm figuring I can't make things too much worse than existing lol.
I have a 6200 watt Powmr inverter connected to a 4000 watt solar array and a 10Kwh Chinese server rack battery. I installed a ground rod and grounded the solar array, combiner box and inverter ground screw to it. I've taken three circuits off the mains panel and run then through a new panel that takes the output from my inverter. These circuits are totally off grid. To try and give me a bit of protection I've added a ground fault breaker.
So Inverter ac output >> 40 amp ground fault breaker >> several breakers which supply circuits.
My three circuits are working fine, however when i try and add the kitchen circuit it immediately trips the ground fault. Even just hooking up the neutral will trip the breaker. I have tried unplugging everything on that circuit but the problem remains. When the circuit is connected to the mains panel (no GFI) it works fine and I'm not getting zapped off anything.
Is the only solution to rewire this circuit and abandon the existing wiring? It would be a bit of a project, so wondering if there are any troubleshooting steps I can try first?
