I have a new Chins LFP battery that needs the cells top balanced. The BMS does have cell balancing but is either very slow or isn’t working.
My first charge hit OVP on cell 1 at 3.65 while the other were at 3.45ish
Let it sit overnight and the cells range from 3.574 to 3.411.
BMS won’t start charging again until cells are 3.50 or under.
I plan on discharging this afternoon and testing capacity but was curious the best method to top balance cells in an assembled battery.
I only have a Victron Smart Solar MPPT for charging but am in the market for an external charger if that would help and you have a recommendation.
Thanks
Thanks
