Backupjack
- Jan 8, 2022
- 22
Hi all newbie to Solar and probably an easy fix for you in the know but I have a Renogy 100W lightweight portable panel and a separate Renogy 20amp Voyager Charge Controller, problem is the Charge controller doesn't seem to be putting any charge into the battery .
What I can tell you is when all is connected I get all the correct lights on the controller but when I check my shunt and BMS neither are showing and amps input to the battery.
I tried the set up not connected to the battery and got 18v at the input side of the charger controller but no voltage on the output side, when all connected controller shows 13.3v with 1.2 amp being drawn ( very dull day just for test purposes) if anyone van throw any light on it would appreciate it
