Charger 14s 48v 58.8v 20a for Life4po 16s/48v/30a possible?
Illusionmgs
Ua
Hello
I have life4po battery 16s 100 bms 48v/30a
Charger 14s 48v 58.8v 20a for Life4po 16s/48v/30a possible to worked?
14s charger to 16s battery
Thanks
Hmmm, 58.8V / 16 = 3.675V per cell, not far from fully charged LiFePO4 voltage (ok a bit over).
If the pack was 14s then it would be 4.2V per cell, suspiciously close to NMC/Li-ion voltage.
Are you sure it's a LiFePO4 charger??
In reality, it will certainly charge your pack and is unlikely to do any actual damage (the BMS should prevent that anyway).
Are you looking for a permanent solution or just to get some charge into your pack??
Could you post a photo of the labels / rating plate of your charger?
48v 16s 54.6 now charge
But does not turn on the first time. Some kind of breakdown, immediately the relay is activated and the indicator NOT lights up and the charge not begins. Neeed 2/3 restarts
100% charge my Battery 54.6 16s 48v 20a charger
Question about to change for charge 58.8 14s 48v 20a
