I have an Elcon HK-H-H66-25 and yes I mean when disconnecting the charging current. They have two types Enable Switch and CANbus. I have the Enable switch version and use the Chargery charge relay to break the Enable line when the Chargery wants to turn off charging.@Tony you mention battery charger might be damaged if disconnected? I presume you mean disconnecting the charging current. There are other methods of disabling the charger. What type charger do you have? I have an Iota/IQ4 converter which I’ve modified to accept the disconnect signal from Chargery BMS. A relay just switches a small current to reduce charging voltage to a safe level. There are other methods like inserting a disconnect relay at the AC input.
I’ve also had the experience where the Chargery suddenly shows zero SOC. SOC meter displays almost always greater the 90% during my current 8 week camping trip. But suddenly yesterday buzzer started beeping due to low voltage and displaying 0% SOC. The problem I believe is that Chargery current resolution is poor. The AH counter is not accurate due to the dismal current resolution. The BMS reads my motor home quiescent current of 0.7A as zero. Over time the counter gets way out of wack. The SOC meter is useless unless the battery can be fully charged which I presume resets the counter.
Regarding the SOC catastrophic drop to 0, Jason is insisting that I have a bad battery. However, the BMS showed the battery voltage at 53V after the SOC went to 0. My BMS is running so hot that I think it becomes unreliable at a certain temperature. For example, this morning the battery temperature was ~25c while points on the PCB ranged from 39c to 44c with no balancing, charging or discharging. That's with the case removed! I had a fan on the BMS all night. He says removing the case and mounting a fan is essential.
