Or longerWouldn't that take about 35 hours to charge 400ah of batteries @10a from 20% SOC assuming no load while charging?
Thank you very much. Can I run the chargers while the system is under load.well since you have two chargers i'd just click negative on the negative bus at the bottom and positive at the positive bus on the bottom and do the same at the top with the other charger.. and then set it to about 57.5 or so and wait a few days... as was mentioned. set the voltage BEFORE HOOKING to the bus. They will run at max amps for a few days.. then they will back off as the voltage approaches the 57.5 area.. of course 3.65X16 cells would be 58.4 but I don't like to pump them up that tight. I wish you success.
Yes, it will just take longer. You probably wouldn't want your banks SOC to go below 20% while charging AND under load.Thank you very much. Can I run the chargers while the system is under load.
you can but if you are drawing more than 10 amps you will not be gaining at all. you could run some led lights or a computer maybe or charge some cell phone but any more than 10 amps and you will be using it as fast as you are charging it. You had just as well power the load from the same grid you are running the two chargers from. You lose some in heat when you stick 500 watts in the battery from the chargers and then again as it is ran through the inverter to the load. Just as well get it from the grid and let the batteries charge for when you need them.Thank you very much. Can I run the chargers while the system is under load.
Yes. This would be common and ordinary.Thank you very much. Can I run the chargers while the system is under load.
