That will depend on battery type...i.e. the chemistry Lets assume that you are referring to Lead Acid. You can charge these in any series string. Unlike Lithium batteries Lead Acid does not need to be balanced, when they get fully charged they will rise in voltage and off gas hydrogen and oxygen from the distillation of the water in the water acid mix. The acid does not distill in the process. Only the water is lost. Only add Distilled water and only when the battery is fully charged. The mix grows in volume as it is charged.
