josephL
I suspect my problem has been well documented so please bear with me. I currently have a 2.4 kw off grid system with all Outback equipment. My battery bank is twelve lead acid batteries wired in series 70 pound each. I use propane for domestic hot water, cooking and keep the house (which I don’t live in) heated to 50 degrees through the winter. I worked with my solar installer on the entire system which has functioned perfectly for the past 5 years. on three occasions over those years I have hooked up a small Honda Generator to charge the batteries. This has created some stressful times trying to guess where the battery levels might be what the coming weather is, has the snow melted off and so on. on top of that I have a 3/4 mile trail for a driveway, access can be very difficult in the winter.
Determined to find a solution I recently settled on purchasing a Kohler 14kw RCA and use a Magnum Energy AGS auto start to bypass the inverter for starting the generator remotely when the voltage drops to a specified level. My current inverter has only one dc remote Connection which is dedicated to the battery box vent fan. That was where I was at until I ran into this forum which got me wondering if there was a less expensive solution that would function with the Magnum AGS. Ideally this setup would allow me to use portable propane among other less costly solutions. (Kohler generator is 5.5K with tax) Any thoughts or suggestions would be greatly appreciated. Thanks
Joe
Joe
