I have 6 200w 12v panels and 6 100W Panels with the following specs:
Based on some on-line calculators, it looks like my best Combiner setup is
With that data in-hand, I bought a Midnight solar MNPV6 combiner box and 2 15amp 150VDC breakers. I was wondering if the calculated amperage of 15.2amps for each parallel circuit or on the combiner bus bar. Am I cutting it too close on the 15amp circuit breaker?
Also, I am trying to figure out the DC Miniature Circuit Breaker. Am I correct in my thinking is that they serve to protect the wire from the combined amperage coming out of the 2 circuit breakers. Is there anything special about the MCB's or are the just higher capacity fuses. I would also like to get a surge protector. Midnight Solar's solution has to be replaced if it trips. Is there anything similar that can reset?
Thanks
Don Miller
Power watts | Pm | 200 | 100 |
Max Pwr voltage | Vmp | 20.4 | 18.5 |
Max current amps | Imp | 9.8 | 5.4 |
Open Circuit Vltg | Voc | 24.3 | 23.2 |
Short Crct amps | Isc | 10.2 | 5.7 |
Max Voltage | DC | 1000 | 600 |
Max Series Fuse | Amp | 15 | 10 |
PMAX Coefficient | -0.46 | ||
Voc Coefficient | -0.36 | ||
Isc Coeffient | 0.05 |
All identical panels wired in SERIES, then all series strings wired in PARALLEL: | |
Max power output: | 1687.2W |
Max power voltage (Vmp): | 111V |
Max power current (Imp): | 15.2A |
Loss: | 6.21% |
Thanks
Don Miller
