Thank you for responding so what do I do at this point if one of the cells are higher than the rest how do I correct it I'm charging at 30amp set to 28v full and 21v low to be recharged so how do I correct it to balance the batteries out if it is one cell?The attached pic shows the alarm to be associated with an Under-voltage condition not over??
In any case, the Battery Management System is monitoring individual cell voltages, not bulk battery voltage. So it is quite possible that one cell has exceeded 3.65V which will disable charging while the sum of all 8 cells is indeed 26V.
What are your charging set point values. Voltage & Current. How long does it normally take for the battery to get fully charged. Its possible charge current should be lower so the BMS has more time to balance the cells.
The battery management system usually has some type of cell balancing circuit, either passive or active.
Since there is no information about your battery with regard to Amp Hour capacity or Type, I will assume its an 8 cell, LiFePO4 with 100Ah capacity.
Try lowing the charging set up to 27V & 15A and let the battery charge Float charge for several hours then turn up the voltage to 27.5V and let it Float charge for another few hours. Finally increase to 28V and let the battery float for another couple of hours.
If the high voltage alarm comes on at any time reduce the voltage and let the battery float for a few more hours. Many BMS balancers can take a long time to rebalance the cells.
I'm using two 12 volt LiPo 4 batteries each battery is 400 amp hours running in series for 24 volts with the powmr 3000w hybrid inverter I'm not sure how to setup for float charge I thought Lipo4 batteries couldn't be flow charged maybe I'm wrong but I don't know how to set it up for thatThe battery management system usually has some type of cell balancing circuit, either passive or active.
No 2 batteries for each inverter 1 inverter for L1 and the other for L2 they are not tied together I added a second panel each inver us 120vi was just showing the hook up but 2 batteries for each inver don't want to confuse you but the issue is with the 2 batteries in the picture u sent the issue is with the 2 12v batteries that's in seriesEach battery has its own BMS so there is no way to truly top balance both batteries while connected in series. Best way would be to reconnect them in parallel and float charge at 13.7V for 24hrs.
The Pic shows 2 inverters and 4 batteries connected to 1 breaker panel. Are the 2 inverters independent or are they stacked for 6,000W either at 120V or 240V split phase? If so, they should share a common battery bank and all 4 batteries should be top balanced while connected in parallel then rewired to 24V. This would be considered a 2S2P configuration.
How do I float charge them at 13.7 volts if you can tell me that I might can get them back to normal if it works just let me know what to do and I do have a plug in lipo battery charger that I can set the voltage to whatever it needs to be atNo 2 batteries for each inverter 1 inverter for L1 and the other for L2 they are not tied together I added a second panel each inver us 120vi was just showing the hook up but 2 batteries for each inver don't want to confuse you but the issue is with the 2 batteries in the picture u sent the issue is with the 2 12v batteries that's in series
From your images it would appear your battery wiring is substantially undersized for 250 amps ( 6000 watts of inverters ) and series stacking battery's with separate BMS is problematic at best.
Yesterday at 7:08 pm I wrote this. "Best way would be to reconnect them in parallel and float charge at 13.7V for 24hrs."I do have a plug in lipo battery charger that I can set the voltage to whatever it needs to be at
Ok I just put the 2 batteries in parallel 2 12v 400ah and I have a lithium battery charger am I charging the batteries to full 14v? Or if you can tell me what to set the charger on as far as amps and volts to charge the batteries I'm not sure what to do also as far as float charge at 13.7v what do I need to do to do that with my battery chargerYesterday at 7:08 pm I wrote this. "Best way would be to reconnect them in parallel and float charge at 13.7V for 24hrs."
Seems like the 2 statements above are in fact the answer to your query, "let me know what to do".
The batteries are not Bluetooth and the charger does have adjustable settings for voltage and amps.Depends on your charger. Does it have user adjustable settings or is it a fixed voltage device? Go ahead and let the batteries charge at 14V.
Do you have any way of verifying both batteries are taking current and neither BMS triggered a high cell voltage cut out?
I'm not familiar with the Li Time brand specifically with regard to its BMS having Bluetooth communication capability or maybe some alarm LED's so you know what's going on.
