Hi , I am trying to design a solar / wind array to charge 3 "house" batteries of 150Ah (total 450 Ah). One of the questions I have, is that I have thought of 3*310 watt solar panels in one array, to feed an mppt controller then into the 12v batteries ( on a 12v system). I know the basic ohms theory , but it does not seem as simple as using the 310 wattage and divide by 12, to get 25.83 amps, therefore 77.5 amps (parallel configuration) fed to the mppt...or does it. ? I mean the panels i looked at were designed for a 12 volt system, yet ( and this is what i struggle with) the characteristics of one of the 310 panels is maxP (V) 31.77 volts and maxP (I) 9.13 amps. This seems to say, if i connect the panels in parallel, then the max current flow to mppt would be about 3*9.13 =about 27 amps. So what is correct, as this could make a difference in mppt required. Does it go with because the batteries required 12 v, then the current pulled down by the controller is 77.5 amps ??
