Say 2 cells at voltage difference about 10mv, is it safe to connect them?
By calculation, assume cell internal resistance is 0.2m ohms, it will have 50A discharge/charge current, quite scary.
Anyone has the experience? How did you connect 2 cells to be 2p? Maybe put a 0.1 ohm resistor first and let it sit overnight, than put on the bus bar?
Thanks for you help!
