You need a main fuse, MRBF with holder as discussed rated at 125% to 150% of maxinum expected current.
You need additional fuses, as close as possible, rated for the current in each of the positive cables. Using buss bars is recomended.
Simple circuit diagram, shunt optional. Note isolation battery switch , if fitted, should be after the main fuse, not as shown on the diagram.
