Snoobler is essentially right. (1) However, I have observed that the Victron MPPT reads just the amount of watts that it is putting into the batteries and not the amount of watts being produced by the solar array. I will occasionally turn off the battery charger and slide the RV slide outs in and out to burn 12 volt power to see charge controller wattage output go up.
(2) The thought was to try to get the charge controller to provide more wattage to the power inverter when it is needed as opposed to waiting for the batteries to be drained first.
I suspect there is little difference if any at all.
For HaldorEE, I have a 70 breaker / disconnect between the positive terminal of the Victron smart 150 / 60 MPPT and the batteries.
