Newbie Question:
I have an AiLi battery monitor shunt. I also have a Daly 250 amp 24 volt BMS. The main negative of my battery is connected to the B- of the shunt. Does the P- of the shunt connect to the B- of the Daly, or does the P- of the shunt connect to the P- of the Daly? Whichever is not connected goes to a busbar to the negative charge/load. Is that right?
Thank you!
Thank you!
