Bananaman321
⚡solar idiot ⚡
Wondering where would be the best place to connect "siemens fsd-100 serge protector" to "whole house backup with supply side tap"
Normally this would be to the main panel where "earth ground neutral bond" is located but this does not protect the inverter from grid L1,L2, serges witch is one of the main pieces of equipment I'm trying to protect by installing this.
My thoughts were to install to main disconnect between inverter and feeder tap and run neutral wire back to main buss terminal witch is close enough to reach with included wiring,
Or directly to the inverter grid tie lugs, neutral, and ground buss bars witch are only 5' of wire length away from main bonded panel.
Seguestions welcome
Seguestions welcome
