TheFlumph
I know this has been discussed here, but I think my situation is a little different. My meter and main breaker are one box attached to a shed 40' from the house. The Breaker at the meter has a ground rod and appears to be bonded to the neutral (like the diagram below says to do) but from there only L1, L2, and neutral leave the box enter the house via underground pvc conduit and land at the main breaker panel in the basment. The ground and neutrals are bonded in this panel. This panel has its own ground rod.
So when I hook everything up as in the diagram, I'm unsure where the bond needs to happen. I've read that It needs to happen at the first OCPD, which I'm thinking will be my feeder tap breaker? Or can it just stay in my main breaker panel? I was also reading that in my situation, the three wires entering the house can be considered feeders and not service lines from the Main service breaker and dont require the EGC to be run.
also, bonus question, the diagram shows a separate ground running from the feeder tap to the transfer switch even though its also going there via the feeder tap breaker. That seems odd to me.
