WattAboutThat
- Dec 15, 2021
- 123
When considering Neutral Ground Bonding
in a Completely OFF GRID system…
If instead of a an electric company grid transformer supplying electricity
as the source of power,
we now consider a
completely OFF GRID solar outbuilding,
as the originating source of power
(some distance from service structure
where a main service panel
will be the Main Panel).
1) Do we treat the outbuilding
as if it were the essentially a grid supply?
2) Do we create a neutral ground bond
in the outbuilding,
as if it were the pole transformer,
since the source of power
is generated there?
3) Do we create a neutral ground bond
at the Main Service Panel,
located in the service structure,
not near the power generating
out building?
4) if there is a NG bond
at the power producing outbuilding,
and a NG bond
in the service building,
if a short circuit or ground fault occurs,
a) WILL IT TRIP THE BREAKER
in the Main Service Panel
located in the service building?
b) will it trip the breaker
in the power outbuilding
that feeds
the main service panel
c) should each building
have their own ground rods?
5) In the power producing outbuilding
can the DC side and the AC side,
use the same Ground rod?
or will this create an issue?
This is a tough one to figure out,
I need all points of view and considerations.
Because I dont want anyone to get hurt,
and want maximum safety accounted for
in the design and install.
I have watched tons of videos
by electricians, but nothing explains
what to do,
if you are the electric company side,
and supplier of the power source, and
you are also the customer side,
and serviced building.
Thank you
we now consider a
in the outbuilding,
is generated there?
out building?
and a NG bond
that feeds
what to do,
Thank you
