AZ Solar Junkie
Maricopa, AZ
I'm pondering possibly getting a Victron autotransformer to balance the loads on the 2 legs from my 6000XP. If the legs were close to perfectly balanced, I would be able to run my electric dryer without needing to get a second 6000XP, as when the dryer runs one of the 2 legs is just enough over the inverter capacity to cause it to switch to bypass. What I'm not sure about is how to handle the N-G bond in such a scenario, since the autotransformer would be creating a new neutral. Is it as simple as having the neutral from the autotransformer connected to neutral in the loads panel, and also having the neutral (and ground) from the main panel where they are bonded, also connected to the neutral and ground bus bars in the loads panel? This means the neutral to the loads is effectively connected to both the autotransformer and to the main panel - not sure if that creates some sort of issue...
