Hello, hope you all are doing good.
I have an Hybrid inverter which I intend to feed DC solar energy to (if available), and automatically switch to AC mains when the DC power is not enough.
Although the inverter accepts both AC an DC input, it does not have the function to automatically choose.
The solution I am trying to implement is a smart solar cell (Zigbee), that below the chosen luminosity will switch to mains, but if available, will always choose the panels.
There is a contactor with it's coil beeing fed by the mains, but the load poles carry the + and - from the panels. The AC energy goes into the contactor's coil via a Zigbee smart circuit breaker.
If the luminosity is below the defined, the breaker will cut energy to the contactor's coil, wait for 10 seconds and then another smart breaker will change it's state to ON, feeding AC energy to the inverter.
My question is: I know that the contactor I am using isn't suited for this. Do you have any idea if there are available DC contactors with AC coil?
Also, if interested provide your thoughts on this, and let me know if you think there is a better and safer solution for this.
Thanks in advance.
Thanks in advance.
