Hello Everyone,
What is DC/AC Ratio? Google answer was: "The ratio of how much DC capacity (the quantity and wattage of solar panels) is installed to the inverter's AC power rating is called the DC-to-AC ratio, or DC load ratio"
So is this ratio only the input PV capacity v/s output inverter capacity.... Does it have anything to do with Inverter performance?
i.e. The GroWatt Inverter says the DC/AC ratio is 2/1.... Does that means it will generate 1 KW AC for every 2 KW DC.... I may be completely wrong here but just wanted to clarify.
Thanks,
Dinesh
Thanks,
Dinesh
