Hello,
I am designing the solar system and need experts advises about cabling, earthing, breakers, switches, contactors, fuses, etc....?
I will bring a specialized company but not confident their design will be as per best practices
Current is 230v, will be connected to 2 apartments to share the full output of both inverters for the total of 11kw, planning to expand the same in the near future to 3 inverters in order not to overload the current ones.
Thank you
- 2 Voltronic Infinisolar V IV 5600w configured in parallel
- Every inverter is connected to 2 strings of 7 panels 545w, 49.65voc . Total 28 panels installed on roof bricks towards south (max sunlight)
- Connected to 10kwh Growatt LFP battery system
- place is 1000m above sea level, temperature varies -4c to 35c
Thank you
