dwhipple99
- Jul 17, 2022
- 7
Team, I am looking for a little help and guidance to get started. I am a techie, with primarily a software engineering background, but some electrical and electronics background, so I am not totally ignorant, but I am definitely learning allot about the Solar market in the US right now. I have a 2500 sq. ft home/cabin in PA (16340) that I want to move to off-grid capable in phases over time so that I can not have to purchase all the required components at once. My house actually uses very little power relatively speaking, the largest two draws we have is an electric dryer, and a 220V well pump. My 12/15/23 to 1/15/24 electric bill has me using 1359 KWH used. Total for the last 12 months is 7614 with an average monthly use of 692.
All that said, I do want to build a bit oversized because I have several outbuildings including a garage and a horse barn I am providing power too also. I currently have a 4500 watt propane generator with a manual interlock switch to power the entire house when we have a power outage and it's worked fine. I want to start my path down power independence by installing a all-in-one inverter and a battery bank, so rather than having to manually switch over to the generator, we can do more like a 50 millisecond failover to the battery bank. That would be Phase I.
In Phase II, I would add the Solar panels and possibly additional batteries if needed. My little bit of research has me narrowing in on either the Sol-Ark 12k or 15K all in one or the Schneider system with several components but I am not exactly sure what yet. The Sol-Ark sounds and looks like it would be the easiest for a newbie like me to install, but I really like the ability of the Schneider to handle unbalanced loads and surges.. I eventually want to get where I have approx 18 - 400 watt panels charging the battery banks with an automatic failover from grid power to battery power when the grid goes down, and in addition, I want the generator to autostart with a remote 2 wire start when the batteries reach a certain level of charge. As I said, I want this in phases, so in Phase I if I could buy a set of batteries and an inverter that can ultimately control a generator, I can install that. I will use my existing generator initially to top of the batteries as required manually during power outages, and then I will add the Solar panels and an upgraded generator capable of APS. I also have 100 acres here, so I was thinking it would be much easier long term to do a ground mount system for the panels, but the solar companies I've spoken with all think I should put them on one of my pole buildings roofs.. Thoughts on this? I do have great and very clear southern exposure for either ground mount or rooftop mount.
So I am a little foggy on what would be the best system (I think either Sol-Ark or Schneider) and I am wondering if I am thinking about my phases correctly. I know I need the inverter and some batteries, do I need solar panels to get started? maybe I start with a smaller batter bank and a few solar panels and then add to the system over time?? Am I thinking about how to phase this in the best way?
Any advice is greatly appreciated.. thank you! My goal would be to spend somewhere between 5K and 15K in each phase, so I could do it out of pocket rather than a 25 year loan from a solar company..
