captainrivet
- Jan 27, 2020
- 73
Hi all,
so I finally finished the installation wiring diagram of my 840AH 12V LIthium house bank on my catamaran.
Could you please review the diagram. I use the Electrodacus BMS which controls everything via remote on/off and has full control over the load/charge on cell level. its also current free means upgrading system is no problem,, Thats why you don't find any big chunky and expensive high current relays or SSRs.
Well the cat doesn't even have a main fuse yet, so while getting the lithium installed I also clean up the french/UK/spain "install cooperation" called newbee rats nest....
All fuses 100A and above are NH 0-2 fuses and main fuse is a chunky 630A NH3 fuse which also work as high current off/on switch, just pull or insert the fuse with thr puller tool (located fixed in the fuse area)...cheap,reliable, sturdy, longlivity and made for the high current constant use. The holders are quite expensive but you can get them on ebay for a steal, just bougt 5xNh0 and 8x NH1 holder plus a 630A NH3 fuse for 60Euro...never used spares from a factory that got knocked down...you get one class T fuse holder for that...
The 230V diagram is not included, I need to finish it first but that is mainly legacy system with a small change in a different main 230V cable upgraded from 3x2,5mm to 3x6mm to be able to handle 6kw and change main 25A breaker to 32A version and a seperate 16A plug+fuse just for the induction cooktop.
The catamaran is setup to be fully self sufficent and even when I am in a marina I don't plan to hook up to shorepower/grid. The gridcharger is actually planned as backup to charge via a portable Honda gasoline generator that is then simply pluged into the shorepower connector. So i am ok with flippng a manual switch to switch to real grid and adjusting the power assist level accordingly if I plug into shorepower. thats why I chose the multiplus and not the 1000Euro more expensive Quattro which could handle that automatically, hardly ever need it and if manual operation is ok.
I am running a full electric galley on my catamaran which is the main power draw but only for short periods of time. This consist of a 3500W 3 burner Bartscher 3512 commercial grade induction cooktop and a Panasonic Mircowave/Convection oven/Steamer combo with 1100-1400W. Mostly only 2 burner of the cooktop will be used, so thats max 2200W draw= 200A which the victron multiplus can handle alone.
But sometimes I will use all 2 or 3 burners plus the convection oven and then I need 2500W+1400W=4kw so 350-380A for maybe 15min max and then I will boost the multiplus via its power assist function and use my legacy 3500W HF inverter as fake grid. This supplies 10A or 2200W (adjustable 4-16A, but 10A will be standard) and multiplus regonized AC input and its transfer switch routes the 10A AC 230V through and the rest the Victron will deliver via power assist what is needed above 10A or 2300W. To prevent the multiplus from using part of the fake grid 230V its charger is shut off via Temp input automatically when the Edecoa inverter is on and delivering 230V.
Battery pack is3p4S 12V 840AH measured capacity and bulid with 10mmx20mm thick tinned plated cooper busbars to be able to deliver continous 500A. Means I can fire up Cooktop and stove to max 3500+1400W=4,9kw and still have some margin to 500A.
both inverter togehter can deliver 3500W+2400W=5,9kw if needed.
Major charge source are 3 Bifacial solar panels with each 445W=1335W each panel connected to its own Victron 50/100 Mppt.
DC-to-DC alternator setup: ENgines are new D2-50F with the new 115A mitsubishi alternators, which deliver around 60A cont.
THe legacy charging system works that if any of the 2 engnies running that thy Victron Cytrix battery combiner combines both FLA banks and charges it.
So I use 2x 30A Victron DC-To-DC charger in parallel connected to the STB engine room busbar. So if each of the engine=one alternator runs, the one alternator is maxed out as one can do 60A cont. savely. If I use engine longer is mainly 1 engine that runs. if both engines run its still the 60A charge, loose some charge cpapbility but thats ok and won't happen often. Main goal is to have the alternator running savely and as cheap as possible when motoring and maxing one alternator out if one is running longer periods eg motorsailing...
Thank you.
Christian
Thank you.
Christian
