Looking to get some used panels, to maximize a , SPF 3000 TL LVM-ES.
Not real sure if I need the (ES)? Ground mount panels, with a EG4 LiFePO4 48v battery.
My question is, what is the determining factors in using micro inverters on panels?
Thinking they were to be used for longer runs to prevent a large voltage drop, by changing to AC?
My plan, will put the panels about 200’ + from the controller/batteries. I also will have shading issues
with some trees. Also understand Micro’s help with shade? Do I need micro-inverts for this length of run?
How to Compare Wire size cost vs Micro Inverter cost?
Also looking for the best panel configuration, (Max. Watt) being cost effective when looking for used for this Growatt 3000
with a 200 foot plus length of run!
Thanks for your Time
Bill
Bill
