arzaman
- Nov 9, 2022
- 44
Hi Guys
I'm getting crazy to tune the battery charging parameters of my Deye 5Kw hybrid inverter and don't find a reliable source to understand the exact behaviour of each single parameter
My 5kw Deye Inverter connected to DIY battery bank made by 16 * 160Ah cells and JK active BMS
No CAN/rs485 connection
Battery Settings: Use Battery Voltage (I try with % but is a mess)
Zero Export to load
All house load connected to the backup load
would like also to understand the meaning of below parameters and how inverter uses these parameters
I basically see 5 parameters related to battery voltage
what is the parameter that controls grid kick out and kick in ?
Would like a safe setting to discharge the battery to 15-20% max but don't find a proper combination
thanks
Davide
Zero Export to load
- battery setting - LOW BAT
- battery setting - SHUT DOWN
- battery setting - RESTART
- time of use - BATT
- Hidden GUI parameter - BATT EMPTY V
thanks
Davide
