crossy
Our two 5kW Deye hybrids are working very nicely with an Eastron SDM230 meter instead of the CT. Seems to control zero-export much more accurately than the supplied CT (which was probably at the cable distance limit anyway).
Minor issue is that when the grid is down so is the meter, the inverter responds with an annoyed beeping and a message to check the meter. Surely it knows the grid is down and shouldn't be alarming. Anyone know how to mute or disable?
Also, I'm going to add a grid-tie inverter to the Gen port, I see a setting to have a meter there but no indication if there can actually be two meters or what address to set it to. Any ideas??
