Hi there,
I have a couple of doubts regarding the wiring for the SUN-8K-SG01LP1-EU inverter.
These are the specs for this inverter regarding PV string input
I am intending to connect 18 panels. Since there are 3 panels affected by morning shadow and the other 3 affected by afternoon shadow, I thought to connect two strings of 6 panels and two strings of 3 panels. Here are the specs of the panels to be used:
My doubts are:
1) The inverter MPTT volftage range indicates 150 to 425. On the 6 panel strings is safe (298,8v), but on the 3 panel strings is under the below the indicated range (149.4v). Would that be a problem? Should be a minumum of 4 panels for each string?
2) The PC invput current is indicated at 26+26A. So I presume that this 26A per MPTT tracker, and 13A per string. The panles indicate a current of 13.12A. Could that be a problem?
3) Could you forsee any other problem with this configuration?
Many thanks!
My doubts are:
Many thanks!
