A charger takes power in and converts it to what a battery needs to be charged.I know what a Solar Charger is, but what is an MPPT Inverter?
I had seen some regular "inverters" on ebay that were advertised as a MPPT Solar Inverter (not the all-in-ones)'An all-in-one unit comes to mind vs separate single function components
MPPT solar charge controller + inverter + auto transfer switch combined into a single unit
Can you share a link or actual add to show the wording? Advertising can be misleading sometimes
When I type in "MPP Solar Inverter" to ebay I get all-in-one units like this:
This a very cheap all-in-one - The "MPPT" is just short hand for "MPPT Charge Controller" function. So this is advertised as MPPT Charge Controller functionality + Inverter that can take up to 1000w of Solar Panels in the 20v-45vdc input range.
MPP is a brandWhen I type in "MPP Solar Inverter" to ebay I get all-in-one units like this:
Agreed - I ment to type/say "MPPT Solar Inverter" ...MPP is a brand
mppt is a controller type
I wouldn’t shop for anything on eBay and would say be careful on amazon
The photo/ actual inverter appearance is somewhat misleading, it looks like what most would consider a normal inverter.This is a very illegal (and dangerous) PV grid tie micro inverter that plugs into a wall outlet. It takes in PV panel power and pushes AC power to grid.
Ha! I've got an old one very similar to that one but only 750 watts.Wow! That inverter ad looks sketchy as hell! I'm cheap but not THAT cheap!
Yeah....that 'Grid Tie Inverter' is the krap!The photo/ actual inverter appearance is somewhat misleading, it looks like what most would consider a normal inverter.
I missed that although it says "Grid Tie Inverter" on the photo. To confirm I Googled and found the actual listing:
https://www.ebay.com/itm/164854203112
This inverter is NOT to be considered for use in a off grid system.
