Hi guys,
I've had my 100ah battery wired into my car for about 6 months. 4s configuration, 120ah JBD BMS. It mainly runs my fridge and some 12v accessories. It is charged by a 20a lifepo4 DCDC charger.
When charging, I've noticed that one cell tends to shoot up past 3.65 up to about 3.8 while the other cells are ~3.4. Charge protection will then kick in, and the cell will slowly drop to 3.4V. When discharging, some cells would drop to ~2.8. These BMS settings are the standard "LiFePo4 Normal" settings. I thought I would use the Overkill Solar standard 4s BMS settings, which keeps cell voltages between 3.0V and 3.4V. I saved these settings to the BMS, and carried on with my day.
Now I've noticed that the BMS is preventing cell discharge; if I tap the button it will momentarily change to enabled, then flick back to disabled. When charging, the discharge button will move to enabled, but current won't flow i.e. my fridge won't turn on.
I've disassembled the battery and checked each cell with a multimeter and cell voltages are as measured by the BMS. The screenshots below are of the cells and BMS only, no charger or loads attached.
Any ideas?
Thank you
Any ideas?
Thank you
