deanwards
I'm hoping someone much smarter than me can shed some light on this experiment.
Goal Zero Yeti Lithium 1000 inputs are rated at 14 - 22 volts. So, I bought a 5 amp 12v to 19v step-up converter to connect with a 100ah LiPO battery. On paper this should deliver about 95w to the yeti from the battery. I wired it up and tested it with a multimeter and sure enough 5.4 amps at 18.99 volts, well within the specified range. Plugging it in to the Yeti PWM, I get nothing, no lights, nada. Plugging it into the MPPT does register, but the wattage jumps around between 46 and 53w and doesn't stabilize. Out of curiosity I plugged it into a Jackery 500 and got a steady 41w.
I was under the impression that 5a x 19v = 95w. Is it not that simple? Is there some other factor at play here? Shouldn't 19v be in the typical range of a solar panel output? BTW, The Goal Zero chargers (Their 12v step-up, and ac charger) output around 4.6a at about 15.5 to 16v.
Scratching my head why this ain't working. Any thoughts would be appreciated.
