(Spoiler alert - there is no PWM)
I’m adding a small 750W DC-coupled ‘bonus’ array to my grid-tied array and want to use relays to switch off a grid-tied Microinverter in late morning when my large grid-tied array starts getting up close to peak output (due to export power limit).
From ~noon to 4pm. I want to use that bonus array to charge a 24V LiFePO4 battery and have been planning to get an MPPT that will be switched on and off through another (larger) relay connecting output to the 24V battery.
Going over cost-benefit and knowing that my string voltage is only 2-3 V above my battery voltage, I’ve decided it makes sense to save money by getting a PWM SCC rather than an MPPT.
But when I think about the fact that I’m switching the PWM SCC on and off using a relay and reviewing how a PWM SCC works, it occurs to me that I could just directly connect the 30V string to the battery.
String voltage will be at Vbat which is 2-3V below Vmp, but since current will increase from Imp to Isc, total power loss will only be ~5% (same as it would be with a PWM SCC).
I’ll need to monitor battery voltage to turn off the relay as the battery gets charged up enough to enter CV mode (I have another string charging the battery through an MPPT so I’ll know when to disconnect the ‘bonus’ relay.
I need yo think about fault tolerance to assure that the bonus relay is always disconnected once the battery is fully-charged, but other than that, is there any other reason direct charging of an 8S / 24V LiFePO4 battery from a 60-cell / 30V PV array will not work?
Has anyone heard of anyone else performed direct charging of batteries from PV arrays like this?
If I’m only direct-charging for a few hours near midday when the battery should be in CC mode, does anyone see a problem with this that I’m missing? (I realize there is no logging / reporting and that is not important to me).
