sunshine_eggo
Happy Breffast!
Battery:
4S 25Ah Topband Navitas 3C cells.
120A JBD BMS
UART to USB adapter from Overkillsolar
Bluetooth module uses the BMS UART connector, so it was not installed.
VRM:
Raspberry Pi 3 B+ 1GB (RPi)
256G MicroSD
Venus OS 3.11 start, 3.12 end
@Louisvdw serial battery driver
There were NO LOADS applied to the battery. It sat there plugged into the RPi.
Started 10/28/23 22:00
Ended 12/14 18:00
Here's the overview showing BMS reported Voltage, Current SoC, Min and Max cell voltages:
Nope. I have no idea why the SoC dropped from about 63% to about 28%. This did coincide with a notable voltage drop. There must be some criteria that causes the BMS to adjust SoC based on voltage.
Worth noting that at no time did the BMS report a current - always 0.00A. I would assume this has more to do with the inability of the BMS to measure small currents AND/OR account for current IT uses.
Here's the drop:
It makes no sense. With min and max cells at 3.30/3.31V, the 68% was much closer to accurate.
Oh well. Here's the drop from 19% to 0% while only dropping from 13.10V to 12.96V and cells from 3.28V to 3.24V.
Voltage and cell delta stayed pretty constant ... with 0% SoC for another 8 days:
Here's where discharge protection kicked in at 10.81V and 2.50/2.83 min/max cell V:
Clearly, once discharge protection was engaged, less current was being drawn as the battery and cell voltages rebounded a bit.
Let it keep running until we got really low, 10.29V, 2.31/2.76 min/max cell V:
And here's the recharge:
Very pleased with the retained top balance... 3.60-3.65 @ 14.5V before protection was engaged.
The jump to 100% was due to my BMS set to 100% @ 3.45V.
Summary...
47 days
Self-discharged to lowest cell at 2.31V
Recharged to .05V delta at 3.65V peak
I can only conclude these cells are very well matched to each other. Prior to this test, when I first got them, these cells tested just over 25Ah as a 4S pack.
Average BMS draw was:
25Ah / (47 days * 24 hours/day) = 0.022A or 22mA
I expect this was due to the continuous communication with the RPi. I have let this battery sit 6 months with the bluetooth module attached, and it didn't discharge nearly this low.
Whatever is going on here, it's a fixed thing. I specified 250Ah instead of 25Ah, and the SoC dropped at about 1/10th the speed, so this SoC drain is unlikely to be an accuracy issue on a larger battery, particularly if it's regularly synched.
Lasty, taking a look at the termination values...
At 3.45V/cell, 90.8%, 5.22A (0.21C), 21:56
At 3.65V max, 3.96A, 22:17
That's 4.59A avg for 21 minutes or 1.61Ah or 6% SoC
Cut off was at 0.16C @ 3.65V, so the battery isn't quite fully charged, but it's darn close.
120A JBD BMS
VRM:
256G MicroSD
Ended 12/14 18:00
Here's the drop:
Summary...
47 days
