BipedalPrimate
- Mar 25, 2022
- 61
Have completed individual full cycle cell testing for 16 LF280K cells which demonstrate an average capacity of 307Ah (Min 305.3, Max 308.4, SD 1.1Ah).
First full charge to 3.65v resulted in about 220Ah charged for each cell. Appears they were shipped at 21% SOC Nominal.
On completion of each cell full cycle test, cell was then discharged at 40A for 1 hour.
Doing the math suggests that cells are now at 95% SOC Nominal (267/280) or 87% SOC Measured (267/307).
Cells are now at an average Voltage of 3.332V (Min 3.329V, Max 3.335V).
Cells arrived with an average Voltage of 3.289V (Min 3.287C, Max 3.292V).
Cells will be stored in boxes & insulation they were shipped in (lots of foam padding) in partially insulated store room at 37S close to coast during Oct/Nov - do not expect low (<5C) or high (>30C) temperatures during southern hemisphere spring. (En Nino may have something to say about though.)
As I will be traveling for the next 2 months, my question is should I be concerned about the high'ish SOC or Voltage during my absence?
High'ish in this context is above recommended storage SOC (50%) which corresponds to cell Voltage of 3.25V as per discharge testing - can expect cells to rebound to approx. shipped Voltage or slightly above after discharge to that level.
